I have a simple program which is only responding to my serial isr. I am using TI's MSC1210Y5 which has two UARTs on board, Port 0 and Port 1. I want to turn on a led when I receive a character on Port 1.
The serial interface is set up as follows:
// Set Serial Port 0 SCON0 = 0x50; PCON |= 0x80; //Set Baud Rate doubler for Serial Port 0 // Set Serial Port 1 SCON1 = 0x50; EICON |= 0x80; //Set Baud Rate doubler for Serial Port 1 // Set timer 1 up as a baud rate generator. TR1 = 0; /* stop timer 1 */ ET1 = 0; /* disable timer 1 interrupt */ TMOD &= ~0xF0; /* clear timer 1 mode bits */ TMOD |= 0x20; /* put timer 1 into MODE 2 */ TH1 = (unsigned char) (256 - (XTAL / (16L * 12L * baudrate))); TR1 = 1; /* start timer 1 */ // Clear Serial Rx Flag RI_0 = 0; RI_1 = 0; // Clear tx flag TI_0 = 1; TI_1 = 0; // Set serial intterrups ES0 = 1; //Enable Serial Port 0 Interrupt ES1 = 1; //Enable Serial Port 1 Interrupt PS = 1; //Serial Interrupt Priority HIGH
My isr looks like this:
static void Serial_isr(void) interrupt 4 { // Port 0 rx if ( RI_0 ) RI_0 = 0; // Port 1 rx if ( RI_1 ) { RI_1 = 0; led_sys_err_1 = ON; } //__if ( RI_1 )__ }
The problem is that my isr is only triggered when I set
TI_0 = 1
I know you have to set TI_0 = 1 for printf() to work, but why should my Rx on Port 1 depend on my Tx on Port 0?
Thanks.
