Hello everyone,
I am trying to generate the PWM signal for my infineon XC164 DSP. I just want the sample code for CAPCOM6 PWM.
I need the sample code for the Edge Aligned mode and centre aligned mode so that from that code i will start my programming. I will provide my email address here. I hope you will help me.
Email: vivek_tailor@yahoo.co.in
If you need "the" sample code, then it should be possible to download "the" sample code from wherever anyone have posted "the" sample code.
If you want an implementation written by someone on this list, you may have to first negotiate for licensing fees - remember that when a consultant or employee (a lot of such peaople here) write code, they may not be allowed to send away copies of that code because they are either not the owner of the code, or have a contract that clearly stipulates licensing terms etc.
Have you spent any time with Google to search for any sample code? Have you visited the manufacturers home page? Have you looked for other chips with similar/identical PWM and seen if you can find sample code for them? Have you contacted a service engineer at the manufacturer or distributor and asked for sample code? Exactly what have you done - besides posting requests on this or other web forums?
look for Infineon's "Dave" tool.
oops, prank exposed :)
sorry javi :-)
Tamir,
I guessed that it was you ;)
