For those who like programming in Pascal here is Turbo51 - a free Pascal compiler for the 8051 family of microcontrollers:
http://turbo51.com/
It features a fast single pass optimizing compiler, Borland Turbo Pascal 7 syntax, full floating point support, mixed pascal and assembler programming, full use of register banks, advanced multi-pass optimizer, smart linker, generates compact high quality code, output formats include binary, Intel HEX and assembler source.
Igor
this has been discussed in several other fora and what stops me from saying "great" is "an OMF file with debug information is on the TODO list"
ps are Todo and Dodo cousins of Frodo Bilbo? :)
OK, if there are also others with the same need I will put OMF higher on priority list. May I ask you which tools with OMF support are you using?
e.g. the SILabs debugger Ceibo EB51x2 Acqura
sir erac,
i is being wondering what is the omf being used for????
kalib
OMF means this: en.wikipedia.org/.../One_Must_Fall
i is not being understanding!!!!!
one must fall?????
i be thinking you be joke at pooor kalib?????
you be not being kindley!!!!
kalib, Just pooling your leg! sorry for that. An 'omf' file is an executable for the C51. Note that this is still not a HEX file.
A Hex file works well for programming a processor. But it does not contain any debug information. If you run a debugger or an ICE, you need a file format that can map data types and what source lines that produced the individual processor instructions.
temir,
i be thainking you for the good ansewr.
i starting ot be thinking you be as kindly by sir erac :::)))
ho no no no no no no no I am not nearly as smart as he is :)
Tamir only have half the answer and omit the half relevant to this
Per gives the full answer
If you run a debugger or an ICE, you need a file format [OMF with debug enabled] that can map data types and what source lines that produced the individual processor instructions
adn sir erac is very kind and very wise and very old and he is fun with his crazy jokse.
but he is sometime not kind and not wise and not fun in jokes :(
