HI After exucating this two program code AREA armtxt,CODE,READONLY ENTRY MOV R0,#0x0F MOV R1,#0x0F MOV R2,#0x0F MOV R3,#0x0F MOV R4,#0x0F END
AREA armtxt,CODE,READONLY ENTRY Main MOV R0,#0x0F MOV R1,#0x0F MOV R2,#0x0F MOV R3,#0x0F MOV R4,#0x0F END
i am geting this error what is wrong with code
Build target 'Target 1' assembling Startup.s... linking... sd.axf: Warning: L6665W: Neither Lib$$Request$$armlib Lib$$Request$$cpplib defined, not searching ARM libraries. sd.axf: Error: L6411W: No compatible library exists with a definition of startup symbol __main. Target not createderror
"After exucating this two program code"
No, you have not yet executed your code at all!
You have Assembled it, and it has then failed to Link correctly - so you do not yet have anything to execute!
"No compatible library exists with a definition of startup symbol __main."
Your project is looking for a 'C' entry point; ie, a main() - but you haven't provided one (yet).
