Hi all, I've just installed uVision3 evaluation version and Cygnus GCC compiler. In most forum threads there are references to GNU examples that should be found in Keil/ARM/GNU directory, but I can't find them ! Forum entries are a little old, maybe these examples er no more included ? Maybe one of you could send me some GNU examples ? Thanks,
Ok, that makes sense ;-) I will try this way. I hope it will be easy to use this compiler to build a AT91SAM7 based application and simulate it with uVision, that's what i need to. Thanks !
http://www.keil.com/forum/docs/thread12738.asp
