about the pointer point to the function
Hi:
I want to build an array that contain the pointer of some function in our program.
a simulated example is as below
//claim two function
int x(void);
int y (void);
main()
    int *(p)(void)[2]={x,y}
When I compling, such error message appeared" error , an array of function"
Dose keil support the array that contain the poiint of the function?
why I want to do this?
There is an array while the first element is about the total amounts of the function to be execute, and the subsequent element indicate the corrponding function which will be execute.
For example:
int array-A[3]={2,0,1};
//this mean that there is 2 functions(function_0 and function_1) will be executed.
Because of this, I want to build an extra array thant contain the pointer of the function such as below
array-B={function_0_pointer,function_1_pointer};
According to the element in array-B, I will execute the corresponding function directly.
Is this idea can be supported?
Thanks for your replying!
Jason.Liu
