hi ,
i want to build a new digital clock with a procesor and need your knowlege.
what procesor would work for it????? would arm be quik enough????
can i use a 32,768 hz watch crystal???? but would it make it slow??????
all help will be kind.
(chief programmer zuisti)
Why would it not be?
Thnk about it: all a digital clock needs to do is to count up by 1 every second, and remember that every 60th second counts 1 more minute, etc...
Even an 8051 would be overkill for that!
You could do it (and many have done it) with just a few basic counter chips!
electronics.howstuffworks.com/digital-clock.htm
In fact, you probably should do it first with basic counter chips - so that you really understand the foundations of what's going on.
Once you really understand how it works, it will be easy to implement in software on a microcontroller...
zeusti,
please, please, please can you tell me what exactly is a:
(senior chief programe)
Sounds like something out of Tron.
The original compiler was written in Oberon by Niklaus Wirth (the designer of Pascal, Modula-2 and Oberon etc.) to run on the Oberon operating system. I translated the compiler to Component Pascal to enable it to be run on Windows.
The original compiler assumed that the entire target application was running in RAM. I had to rewrite the parts that accessed globals so that resulting applications could run out of the mixed ROM / RAM environment of the LPC2000 family.
That was the hard part.
The remainder of the work entailed implementing an LPC2000-specific linker, integrating the whole lot into the IDE that I had previously written to be used with Component Pascal:
www.cfbsoftware.com/cpide
and adapting the language-sensitive features of the IDE to Oberon-07.
18-Dec-2008: "chief programmer"
20-Dec-2008: "senior chief programe"
But still no idea how to do a simple digital clock!
With seniority, comes forgetfulness. He might have forgotten more than most here have every known. Who are we to know?
The advantage is that what has been once known should be easier to learn again.
can u give me some time i will build one for u with 7 segment calunder. i am busy with "c" now. by the way which topology u want, multiplex or shift regaster and also cpu.
A One Step Journey Start With A Single Step
"A zero step journey starts with one step forward followed by one step backwards"
A One Step Journey Is Single Step
A One Step Journey May Be A Stumble.
sohell brigmoob .
, thx 4 youre' help for me .. i was b4 think thare were no good profesionals' here!!!!!
lokking just u and me.
yes and we appresiate the ideom.
zuisti
(chief engineriing programer)
Do you really think that insulting people will make them more willing to help you?
engineriing
I'm sure you did not mean "engineering", right? Going up the ladder I guess - soon you'll probably be designated "master chief engineriing programer etc. etc. etc."
There are a lot of professionals on this forum. Here's how you can tell who the professionals are:
A professional in need of help will: -provide a clear and concise statement of their problem, including design goals, examples of code, and SPECIFIC points of failure of THEIR design. -READ AND UNDERSTAND the help that is given to them by others. -Implement the changes suggested by others and provide DETAILED feedback about what works and what doesn't
You, sir, have done NONE of these thing in this thread or any of the others you have started.
So how long should we let Worldwide Chief Master Mind Executive continue with this joke?
(minor league fiddler)
I was thinking the master chef was sounding a bit like a 419 scammer, or this thread was something like scam-baiting.
Haven't seen the post about his rich Nigerian uncle/cousin/associate yet though.
There is probably this competent and productive company that can do consultancy jobs within all fields - 30% up front, 50% on delivery and 20% on customer acceptance.
Right now, we are only seeing the sell-in phase where the technical lead presents himself and convinces us that he is representative for the company.
