printf
I am trying to run my first C program on Keil...it works perfectly until I insert a printf statement...am i missing something?
#include <reg52.h>
#include <stdio.h>
void main(void)
        unsigned int i;
        unsigned int ans = 0;
        for (i =0; i< 5; i++)
                ans += 2;
        printf("The answer is: " + ans);
  • Yes.
    1) You are missing your description of your problem.
    2) You are missing how printf() is expected to work. If you add a string and an integer, you will create a new string pointer into some unknown address of memory. printf() takes a formatting string with magic characters to inform where the formatted data should be inserted. In this case.
    printf("The answer is: %u",ans);
    Take a closer look at the manual for a description of how to use printf() or any other standard function. Just getting past the compilation step does not mean that the code is valid.
  • Yes.
