Dear Keil Exe..
Can anybudy have technical specification about MDK-ARM.
My Question is about do you know any limitation/spec about MDK-ARM that maximum no of (.c) and (.h) files one project can have, and what is the maximmum code size it can support.
In my case I am having around now 128-129 .c files and 90+ header files with one integration, and combine code size would be over 300 KB , I am using LPC2388.
And I have keil restricted comipler (256 Limit), what should i do further for my project.
-N. John
"code size would be over 300 KB ... I have keil restricted comipler (256K Limit), what should i do"
Surely the answer is obvious?
The 256K limit is inadequate for your requirements - by a significant margin - so you need to upgrade it to the next higher available option!
Clearly this is a question for Keil sales and/or your local distributor: contact details are, surprisingly enough, available via the 'Contact' link on this very web page!
Thanks Andy..
I have reached there...
Put issue here aimed to many developers faced this issue , and by using combination of comilation options like (cross module optimiztion, code optimization level, enabling thumb etc).. will it goes to limit of my comilar or not ?
Read your licence terms carefully to determine precisely what limits apply, and how.
It's impossible to say whether optimisations might get you down from over 300K to under 256K - it depends entirely on the nature of your code!
You're just going to have to try it and see!
