CANNOT FIND UV3.HLP message
Hi All
I have installed the 4k UV3 version V3.51 that came with my latest MCB900 board using XP in the root C:\Keil4k\. Now when I use Help - uvision help - I get message 'Cannot find the 'C:\Keil4k\uv3\uv3.hlp file'.
This file does not seem to be in the installation. Any ideas? Thanks.
  • Hi,
    I have found the same thing in version 3.33. I have inquired with support but have not yet been answered on this point. My IDE also fails to respond to any search target term put into the task bar window at the top (between the binoculars icons) & I believe that it used to do so. I have reloaded uV3 but to no avail. Does your version work as intended in this regard?
  • Hi,
