I have just updated to C51 8.12 and now get this error with every C file in the project. I cannot find reference to this warning in the knowledge base. Only unrelated ones to dongles/ports that are not relevent. I do not use a dongle.
I am using properly licensed software renewed in Dec'07. I have installed another update, 8.11a, previous to this one. No problems at all in that instance.
Why has updating to 8.12 caused these warnings? How do I stop these warnings? Over the top stratergies such as lowering the warning level don't help. Neither can I find any way of disabling individual warnings in the C51 compiler.
This is really annoying and makes solving other problems more difficult. Not only has this update borked the compilation it 'lost' my configuration as well. Even when I specifically ticked the box 'keep'.
Last time I emailed support they informed me I should've used the forum
Well, that depends on the type of question. Licensing questions and bug reports are definitely a matter for Keil support.
OK. Thanks.
Last time I emailed support they informed me I should've used the forum :o))
See: http://www.keil.com/forum
I think you should contact Keil support with this question. This forum is for getting advice from other users, not from Keil support staff (which occasionally stop by, but aren't guaranteed to).
