Dear All,
I am compiling following code.
__asm{ STMDB R0!, {LR} }; __asm{ MOV LR, R0 }; __asm{ LDMIA SP!, {R0} }; . . .
But compiler is giving me following errors for each of above line.
error: #40: expected an identifier error: #666: "asm" must be used with a function error: #65: expected a ";"
Can anybody tell me the solution for it. Please reply me asearly as possible.
Thanks & Regards, Sachin D. Bhujbal
By giving you those messages, the compiler itself is giving you the solutions:
Message: error: #40: expected an identifier Solution: Give it an identifier!
Message: error: #666: "asm" must be used with a function Solution: Use it within a function!
Message: error: #65: expected a ";" Solution: This is probably related to the other errors - fix them, and this will probably go away.
... why are you doing this?
What is it that you hope to achieve by injecting this raw assembler into your 'C' source?!
You appear to have jumped straight into this without much study of the compiler documentation - that is extremely dangerous!!
Sticking raw assembler in the middle of your 'C' source requires a thorough understanding of how both the compiler and the underlying target work
