Dear all,
I use a startup file that includes the AT91F_LowLevelInit() call. AT91F_LowLevelInit() is a c function and is called as followed:
;------------------------------------------------------------------------------ ;- Low level Init (APMC, AIC, EBI, ....) by C function AT91F_LowLevelInit ;------------------------------------------------------------------------------ IMPORT AT91F_LowLevelInit ;- minimum C initialization ldr r0,=Top_Stack ; temporary stack in internal Ram ldr r13,[r0] ldr r0,=AT91F_LowLevelInit mov lr, pc bx r0
Now I want to use the "normal" RealView Startup file but I don't know how and where to modify this file to call my AT91F_LowLevelInit - function.
Does anybody knows, what to do?
Big thanks,
Christian
I don't know your chip, but this should not be too hard: I would say that anywhere after PLL is stabilized (of maybe even before that) and '__main' is called would be fine - you even have your temporary stack for the call. please make sure, though, that your 'AT91F_LowLevelInit' does not use the heap (it is not initialized yet!). just pasting your code in a standard startup file (in the proper location) should do.
