Hello
I'm using: mcb32stmf103rb6t The uvision3 V3.62c Realview MDK-ARM Version 3.23
In my program i need to multiply a series of 32bit ints. Very simple code:
int test1 = 0x01002000; int test2 = 0x03004000; test1 = test2*test1;
When i compile it and view the disassembly in debug mode is says: 129: int test1 = 0x01002000; 0x08004788 4D3F LDR r5,[pc,#252] 130: int test2 = 0x03004000; 131: 0x0800478A 4C40 LDR r4,[pc,#256] 132: test1 = test2*test1; 133: 0x0800478C 4365 MULS r5,r4,r5
The question then is: Why does it use "MULS" when the instruction does not exits in the cortex-m3? And why does it choose an instruction where the MSB are thrown away when when I need the MSB?
An explanation will be very much appreciated Regards Henrik
Yes, a division really is expensive. Especially since quite a number of processors have a hardware multiplier but not support for division, requiring either a huge number of microcode steps or that the compiler calls a helper function in the runtime library.
Another thing is that a good compiler may catch the division and perform a right-shift anyway (correctly selecting logic or arithmetic shift). Many compilers would also catch a 32-bit shift right and notice that they can ignore the shift and just pick up the topmost 32 bits.
But the important thing here is just to realize that the >> operator requires special considerations for signed integers.
In the general case, where the shift length will not place the sign bit at the top of the remaining data, then you should perform 64-bit division instead of shifting to the right. Yes, very expensive. But the alternative is to depend on the grace of a specific version of a specific compiler, and pray that an update does not change the behaviour. Or writing own code that looks at the sign bit and performs explicit sign extension after the shift.
I think the latter is much, much less expensive than the former and should be the first choice in most cases. Of course, the division looks much nicer in the code, though.
By the way: You do have the language standard, don't you? It really isn't meaningful to write C code and then look at the assembly and talk about right/wrong unless you do have the language standard so you can be sure exactly what the compiler is expected to do.
Without the standard, the only result you may get from looking at the assembly output is figuring out how expensive different C constructs are for the processor, and what gain you may get by different optimization levels.
Note that shift right is defined for unsigned integers, where it is ok to shift in one or more zero.
In this case, we are talking about signed integers. Right-shifting a negative signed value gives an implementation-defined result, i.e. it is up to the compiler to decide if it should duplicate the sign bit or not. This according to §6.5.7 clause 5.
In this special case - where we do know that the processor is using 2-complement integers of exactly 8, 16, 32 or 64 bit width) it is ok to perform a full 32-bit right-shift of the 64-bit value and then mask and keep the low 32 bits after the shift.
INT32 test1; INT32 test2; INT32 upper32; upper32 = ((long long) test1 * test2) >> 32;
I want to multiply to 32bit signed ints, and get this 32MSB.
Unfortunately you've been remarkably good at hiding that intent from the compiler and everybody else.
How do make the compiler do this for me?
Get the full 64-bit result, then shift & mask out the part of it you want.
Okay. This is what i would like. I want to multiply to 32bit signed ints, and get this 32MSB. How do make the compiler do this for me?
Just stop it!
If you multiply 2 32-bit values, the result will be 32-bits. Converting that 32-bits to 64-bits will just result in a 32-bit sign extended to 64-bits. YOU MUST MAKE SURE THAT THE MULTIPLY IS DONE IN 64-bit PRECISION.
INT64S test1 = n; INT64S test2 = y; INT64S test3;
test3 = test1 * test2;
or you could do
test3 = (INT64S) test1 * test2;
with the original declarations. The typecast of test1 will force a 64-bit multiplication.
Do not ask the compiler to do something and expect it to do something different. It is supposed to do what you ask, not what you want it to do.
I have now tried to declare two "long" variabels, multiply them and then store the result in a variable which is a "long long".
typedef signed int INT32S;
typedef signed long long INT64S;
INT32S test1 = 0x40002000; INT32S test2 = 0x30004000; INT64S test3;
test3 = test2*test1;
0x08004788 4D41 LDR r5,[pc,#260] ; @0x08004890 133: INT32S test2 = 0x30004000; 134: INT64S test3; 135: 0x0800478A 4C42 LDR r4,[pc,#264] ; @0x08004894 136: test3 = test2*test1; 137: 0x0800478C FB04F005 MUL r0,r4,r5 0x08004790 17C1 ASRS r1,r0,#31 0x08004792 E9CD0100 STRD r0,r1,[sp,#0]
In this code it still only stores the lower 16 bit. The value in r0 should be 0x00C001600 but the actual value is 0x08000000.That or it should use a instruction where both are stored.
"I tried typecasting with "long long" which is 64bit, same result. The LSB are put into the register instead of the MSB."
Typecasting from 32-bit to 64-bit is only meaningful when you have two variables who are _both_ less than 64-bit and you have a target variable that is of 64-bit (or larger) size.
Then the type cast of one (or both) of the input arguments will force a 64-bit multiplication.
Without a type-cast, but with a 64-bit target variable, the compiler will use a 32-bit multiplication (32-bit in and 32-bit out) and then sign-extend (or zero-extend) the result to 64 bits.
In your case, where you place the result in the same variable, that variable must be larger than 32 bits. A type cast of one or more of the inputs will still only store the low 32 bits - nothing more fits. All a type cast could give you is a warning that the result of the expression (of 64-bit size) will be truncated when stored back into the 32-bit variable.
The MULS is a valid thumb instructions (in some cases). Thumb2 includes all thumb instructions.
MULS Rd, Rd, Rm is allowed. MULS Rd, Rm, Rd as shown in your listing is not allowed.
The instruction 4354 decodes to thumb
MULS R5, R4 (notice only 2 registers are defined) this is
R5 = R5 * R4
This sort of looks like a decoding error on the listing except that the ASSEMBLER will generate a valid instruction for MULS Rd, Rm, Rd since it is equivalent to MULS Rd, Rd, Rm and it will not generate an error. (It generates to 2 operand version of the thumb instruction)
This is a full 32 x 32 multiple with a full 32-bit result. Not bytes are dropped, save the excess over 32-bits. If you want a larger result, you will need to define 64-bit variables.
That's exactly right.
So the instruction i s acutally the MUL, but suffix enables the code flag?
Yup, I have chosen the target to be the mcb32stmf103rb, and the cortex - M3, according to the technical reference does have that instruction.
However, the main concern is the MULS. I might be mistaken when i say that the instruction does not exists, but I have checked several referances and I am fairly certain. Is there an explanation?
Thank you for your time Regards Henrik Rasmussen
S is an optional suffix. If S is specified, the condition code flags are updated on the result of the operation.
