porting C code from AVR to 8051
The code does alot of IO port operations.
Keil uses SFR and SBIT declarations whereas the AVR code uses defines to set IO port locations and
byte operations to set/clear/test bits. There has to be a better way than slogging through the text conversion and then slogging through the debug???
