Hello all, I am working with a MCBSTR9 and I just don't seem to be able to get my ADC to get to work (polling). It keeps on giving 0. Here is the configuration proceudre:
static void ADC_Configuration(void) { SCU->GPIOIN[4] |= 0x01; /* P4.0 input - mode 0 */ SCU->GPIOOUT[4] &= 0xFFFC; /* P4.0 output - mode 0 */ GPIO4->DDR &= 0xFE; /* P4.0 direction - input */ SCU->GPIOANA |= 0x0001; /* P4.0 analog mode ON */ ADC_DeInit(); /* ADC Deinitialization */ /* ADC Structure Initialization */ ADC_StructInit(&ADC_InitStructure); /* Configure the ADC in continuous mode conversion */ ADC_InitStructure.ADC_Channel_0_Mode = ADC_NoThreshold_Conversion; ADC_InitStructure.ADC_Select_Channel = ADC_Channel_0; ADC_InitStructure.ADC_Scan_Mode = DISABLE; ADC_InitStructure.ADC_Conversion_Mode = ADC_Continuous_Mode; /* Enable the ADC */ ADC_Cmd(ENABLE); /* Prescaler config */ ADC_PrescalerConfig(15); /* Configure the ADC */ ADC_Init(&ADC_InitStructure); /* Start the conversion */ ADC_ConversionCmd(ADC_Conversion_Start); }
and the main loop:
// configure system clocks SCU_MCLKSourceConfig(SCU_MCLK_OSC) ; SCU_PLLFactorsConfig(192,25,2); /* PLL = 96 MHz */ SCU_PLLCmd(ENABLE); /* PLL Enabled */ SCU_MCLKSourceConfig(SCU_MCLK_PLL) ; /* MCLK = PLL */ // Set the PCLK Clock to MCLK/2 */ SCU_PCLKDivisorConfig(SCU_PCLK_Div1) ; SCU_APBPeriphClockConfig(__ADC, ENABLE); ADC_Configuration() ; while (1) { while(ADC_GetFlagStatus(ADC_FLAG_ECV) == RESET); /* Get the conversion value */ Conversion_Value = ADC_GetConversionValue(ADC_Channel_0); /* Clear the end of conversion flag */ ADC_ClearFlag(ADC_FLAG_ECV); }
as you can see I am working at 96MHz, so I need a prescalar 15 for the ADC. Any ideas?
Thanks in advance
