Free Flash Utility
I'm looking for a free AND fast flash-tool for flashing a board with C164 and AMD29F010B over serial port.
I have tried BVLDWin, but it is much too slow and it breaks at 99% with error:
Error 533: error in downloading process.
I have checked
http://www.keil.com/flash/utilities.asp
And I have even tried MiniMon which looks pretty good, but I am not possible to get a serial communication established.
The big problem of all these tools is that they are not and no more supported.
I have found a link in this forum:
http://www.keil.com/forum/docs/thread5828.asp
, someone looking nearly for the same, but I do not
know if they can make it happen. The Idea here is to use the Infineon Memtool for internal flash programming and adapt it to the requirements, but how ??
Please, please give me any hint how can I proceed, if not I have to buy Flashit, ....
thank you in advance for any Tips
Sammy
  • Thank you for the hint, but the commercial tool Flashit could establish a serial connection and read out some configuration values from HW, so I think the physical communication is possible.
    Today, I have get the first serial connection with MiniMon, I have tried several different Baudrates and 38400 works. Additional special vaues for SYSCON (0x0084) and BUSCON0 (0x04AD) is required. But enabling the flashs with my configuration do not work, no serial connection could be established if I have enabled the Flashs.
    I'm using the 2 x Flashs as address/data multiplexed (16-bit width) and the C164 is clocked with 16MHz.
    Do anyone can give me the correct setups for SYSCON, BUSCONx and Memory setup that I can program the Flashs ?
    And I found the Flash tool from Phyton:
    www.phytec.com/.../flash-tools-downloads.html
    , is it possible to use it ? Do anyone have experience with it ?
    Thank you for any hint,
    Sammy
    Sammy
