C167CS: No Output Signal on Pin P3.3 GPT1
for a speed-controll of a single-phase DC Motor I evaluate the Infineon C167CS-LM on the EvalBoard KitCON-167 from Phytec, with two 256KB RAM and two 1MB Flash Moduls.
Working with the Hands-On Training material I used DAvE to create the code for the GPT1.
In the Startup-File Start167.A66 I changed the following registers fitting the Memory:
- BUSCON0 = 0x04AF
- BUSCON1 = 0x04AF
- ADDRSEL1 = 0x0006
The Target setup under uVison3 is the following:
- ROM 0x0 - 0x4000
- RAM 0x40000 - 0x44000 (does that work for Debugging?)
- Monitor: Phytec KC 167CR (cant find CS?!!) @COM1, 9600 Baud
- 8H-0BH, 0ACH-0AFH reserved
The timer are initialised in gpt1.c as:
- T2/T4 as reload for T3 (depending on Toggle Latch)
- T3 in timer mode with alternate output P3.3
An connected Oscilloscope detects only noise but no pulses.
I am also wondering why all the registers of the timers and the counters itsself are displayed as "0" when I debug after a stop (peripherals menu).
This is my main.c:
#include "MAIN.H"
void MAIN_vInit(void)
  GPT1_vInit();
  PSW_IEN = 1;
void main(void)
  MAIN_vInit();
  while(1) {};
and my gpt1.c
#include "MAIN.H"
void GPT1_vInit(void)
  T3CON          =  0x0201;      // load timer 3 control register
  T3             =  0x0000;      // load timer 3 register
  T2CON          =  0x0025;      // load timer 2 control register
  T2             =  0xC000;      // load timer 2 register
  T4CON          =  0x0026;      // load timer 4 control register
  T4             =  0x4000;      // load timer 4 register
  P3   = (P3   & ~(uword)0x0008) | 0x0008;    //set data register
  DP3  = (DP3  & ~(uword)0x0008) | 0x0008;    //set direction register
  T3CON_T3R      =  1;           // timer 3 run bit is set
What could be wrong?
Thanks for any help!
Mathias
  • Hi Mathias,
    I don't know if you are still having issues. So in case you are, I would recommend not to configure the bus parameters in the Start166.a66 file when using the Keil monitor (BSL and serial port). The monitor will configure the external RAM starting at address 0 to use for code execution.
    Choosing the Phytec KC 167CR should work for the KC 167CS also.
    I would change your target memory settings for debugging to:
    - ROM 0x0000 - 0x4000
    - RAM 0x4000 - 0x8000
    Hope this helps
    -Chris
