tsk_unlock issue/query
We have RTX 3.01 in a product on LPC2214.
We are attempting to isolate a problem whereby a task which is called by 'os_dly_wait' every 350 milliseconds, appears to 'stop' for over 30 seconds, usually after about 4 days running.
This question is to do with an experiment. We have written code which stops 'tsk_unlock()' from calling 'OS_UNLOCK()' (macro in our configuration)under a controlled condition for 30 seconds. The controlled condition definitely occurs, but suppression of 'OS_UNLOCK' appears to have no effect whatsoever on the system. Everything we have carries on normally. Why is this?
All suggestions gratefully received.
  • If you have called tsk_lock and then call ANY function that does a os_block (such as os_dly_wait) the OS will essentially do an OS_UNLOCK() for you. The only other choice would be to lockup your system forever (because you have disabled interrupts with not chance for them to ever be reenabled)
