hi friends am new to embedded C.......
i am tring to write program for adding of two numbers.... But i don't get the result.........
My code is
#include <reg51.h> /* define 8051 registers */ #include <stdio.h> /* define I/O functions */
extern unsigned int getnumber (void); extern void output (unsigned int);
void main (void) { /* main program */ unsigned int number1, number2; /* define operation registers */ bit operation; /* define operation */
SCON = 0x50; /* SCON */ /* setup serial port control */ TMOD = 0x20; /* TMOD */ /* hardware (2400 BAUD @12MHZ) */ TR1 = 1; T1 = 1; /* TCON */ TH1 = 221; /* TH1 */
printf ("hi yuvaraj");
while (1) { /* repeat forever */ number1 = getnumber (); /* read number1 */ number2 = getnumber (); /* read number2 */ printf ("Input operation: '+' (ADD) or '-' (SUB) ? "); operation = (getchar () == '+'); /* get operation */ output (operation ? (number1 + number2) /* perform operation */ : (number1 - number2) ); } }
please help me to get result..... advance thanks for yr solutions
Please read the instructions on how to post source code: www.danlhenry.com/.../keil_code.png
Don't manually re-type the code into the post - use only copy-and-paste;
Note that TABs don't work (well) - use spaces instead,
and don't forget to check it in the 'Preview'...
