how long is the time
Hi friends,i must have you help for this Cereous problum,
i have a code about a digital thermometer using the proc baord. I have compiled this code in microvision ide And the code is compiled and Built with some warnings and it works very Well.
The point is that i have built the circuit in time and it works perfectly.
the code isthis
int wait_1second ( void) delay
   int delay_count ;
    delay_count = 100000;
label:
    delay_count = --delay_count;
    if ( delay_count > 1 ) goto label;
    end_label:
I burn the proc whith the .hex generated and my LCD just show squares and charactors .
I have written the same code using other one and it works perfectly, i don't use assembler, thats the reason why i'm here asking for help. I put this circuit in files .asm & .hex for you to see.
Thanks in advance
