Dear All,
I took the keil sample for AT91SAM7S-EK for mass storage and modufied it for my AT91SAMSE-EK. After the modification the program runs fine and I can use the board as a USB mass storage.
The big problem is the the reading speed on Windows side. Wrtite speed is acceptable. If the PC wants to read something, I read the sector from the flash (wich is pretty fast) and send 64 Byte to the host. After that I wait for the AT91C_UDP_TXCOMP Interupt that should come after the Buffer is empty to transfer the next 64 Byte. But this interupt occurs only every 1ms which slows down the reading speed. Does anybody know why the TXCOMP interupt is comming only every 1ms?
Thanks a lot for the help,
Christian
It sounds like your application isn't using bulk transfers, and then gets limited to a single 64 byte packet/ms.
you problem is the access frequency dedicated to your device: you are indeed using bulk transfers, but in one of your descriptors (don't remember where...) you can setup the amount of time you get the bus. check the your project's descriptors - it is there, I had this problem once! good luck
Dear Per,
thanks for this very fast reply. This was my first idea, too. But "USB View" tells me the following:
Device Descriptor: bcdUSB: 0x0200 bDeviceClass: 0x00 bDeviceSubClass: 0x00 bDeviceProtocol: 0x00 bMaxPacketSize0: 0x08 (8) idVendor: 0xC251 idProduct: 0x1A03 bcdDevice: 0x0100 iManufacturer: 0x04 iProduct: 0x20 iSerialNumber: 0x48 bNumConfigurations: 0x01
ConnectionStatus: DeviceConnected Current Config Value: 0x01 Device Bus Speed: Full Device Address: 0x01 Open Pipes: 2
Endpoint Descriptor: bEndpointAddress: 0x81 IN Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00
Endpoint Descriptor: bEndpointAddress: 0x02 OUT Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00
Maybe you have some more ideas.
Kind regards,
Tamir,
do you mean on my PC or on the AT91. I searched on both but could not find anything.
Thanks for the help,
check your USB_ConfigDescriptor: I think bInterval determines the access time of the device.
I am not sure what bInterval==0 means...
bInterval == 0x00 seems to be OK for a FULL Speed Device. But I checked other Values, too and nothing changed.
After some days off, I'm still fighting with the TXCOMP Interrupt. But everything I tried did not succeed. I also tried to run the AT91lib with Keil RealView and had problems, too.
Does anybody knows a working mass storage application for the AT91SAM7SE-EK or a port of the AT91lib for Keil RealView?
from what I have experienced with USB, many problems are due to poor windows-size drivers (sometimes, they don't even implement the entire USB protocol - see CDC driver for windows XP and 2000...). what happens if you switch to, say, another version of windows?
or even better: did you try it on a Linux machine...?
just tried with another windows and ubuntu and got the same results.
hm. I will go on searching...
just tried the board at my "non-PC-System" (X86 with RTOS) and this system tells me, that the drive is not ready. If I connect the board to my PC everything works (still slow, but works). After that I tried a Keil sample board with LPC2148 and got the same problem at the X86 system. A USB-Disk and a USB-CF-Adapter work fine.
Could it be, that the Keil Mass Storage Samples are a little bit non-standard? Does anybody knows a mass storage sample for the A91SAM7 for keil Realview?
