How can I run a c-file bevor the usual startup code?
Which changes do I have to made in the startup code? I'm working with the lpc2214.
thanks in advance JChris
I am not very familiar with the ARM toolchain, but I would be surprised to learn that you can't call your own C functions before main(). Isn't that just a matter of jumping to a C function from an assembly file? And then, depending on how soon you call it, the C function must be crafted in such a way that it will cope with lack of initialization of, well, you choose what. For instance, a ram test coded in C could be called before the startup code initializes the static C variables.
Well, that's not what the OP asked for. He was talking about running C functions before the usual startup code, not just before main().
