idata
Q1: This is a part of my project code flow explanation. I want to allocate seperate memory location in internal data for the formal parameter local variable - lid. How is it possible using Keil options. By default, it is being allocated in the overlaid DATA_GROUP . I cannot use NOOVERLAY, as the runLineTask() routine is too large.
void runLineTask(unsigned char volatile lid)    //this runs forever
        unsigned char volatile idata i;
        switch(stateChange[lid])//depending on the change in state, a case is selected
                                // and its related piece of code is executed
                case ON:
                case OFF:
                default: -----
void main(void)
        --      //The basic hardware initialization and variables dseclaration
        --      // is done here
        while(1)//this is the loop which runs forever in real-time
                for(i=0;i<NUM_TASKS;i++) //NUM_TASKS = 10
                        runLineTask(i);
Q2: What are the overhead problems on the controller if we use idata type for most most frequently used local variables (in while loops) in my project code?
Please advise.
