Basic C question for CAN implementation
What I am trying to do is load a CAN frame with some calculated data and transmit it every 1s. Additionally I want to compare what I am sending with an incoming message, compare each byte and if they are not equal replace the value of the transmit byte value with it's corresponding value on the received frame. With the code below I am transmitting correctly but even though I am sending the 'receive' frame with different data I am not changing what I am sending. Help?
//initializing CAN control registers
 C1CSR = 0x41; // initializes CAN controller
 C1BTR = 0x3453; //50Kb baudrate
 BFLD(DP4,0x0020,0x0000);
 BFLD(DP4,0x0040,0x0040);
 C1GMS = 0xFFFF;
 //initializing CAN messgae object and registers
 CAN_OBJ[0].MCR = 0x5695;
 CAN_OBJ[0].UAR = 0x60D0;//ID=0x683
 CAN_OBJ[0].LAR = 0x0000;
 CAN_OBJ[0].MCFG = 0x68; //DLC=6,DIR=1(TX), StdId
//initializing data for CAN_OBJ[0]
 CAN_OBJ[0].Data[0] = 0x00;
 CAN_OBJ[0].Data[1] = 0x00;
 CAN_OBJ[0].Data[2] = 0x00;
 CAN_OBJ[0].Data[3] = 0x00;
 CAN_OBJ[0].Data[4] = 0x00;
 CAN_OBJ[0].Data[5] = 0x00;
 CAN_OBJ[0].Data[6] = 0x00;
 CAN_OBJ[0].Data[7] = 0x00;
//end of data bytes
//initializing CAN_OBJ[1]
CAN_OBJ[1].MCR = 0x5695;
CAN_OBJ[1].UAR = 0xE0DA; //ID of 0x6D7
CAN_OBJ[1].LAR = 0x0000;
CAN_OBJ[1].MCFG = 0x60; //DLC = 6, DIR=0(RX), StdID
CAN_OBJ[1].Data[0] = 0x00;
CAN_OBJ[1].Data[1] = 0x00;
CAN_OBJ[1].Data[2] = 0x00;
CAN_OBJ[1].Data[3] = 0x00;
CAN_OBJ[1].Data[4] = 0x00;
CAN_OBJ[1].Data[5] = 0x00;
CAN_OBJ[1].Data[6] = 0x00;
CAN_OBJ[1].Data[7] = 0x00;
//end of initializing CAN_OBJ[1]
//Following data objects are not used but still must be initialized. byte MSGVAL is set to invalid
 CAN_OBJ[2].MCR = 0x5555;//message object invalid
 CAN_OBJ[3].MCR = 0x5555;//message object invalid
 CAN_OBJ[4].MCR = 0x5555;//message object invalid
 CAN_OBJ[5].MCR = 0x5555;//message object invalid
 CAN_OBJ[6].MCR = 0x5555;//message object invalid
 CAN_OBJ[7].MCR = 0x5555;//message object invalid
 CAN_OBJ[8].MCR = 0x5555;//message object invalid
 CAN_OBJ[9].MCR = 0x5555;//message object invalid
 CAN_OBJ[10].MCR = 0x5555;//message object invalid
 CAN_OBJ[11].MCR = 0x5555;//message object invalid
 CAN_OBJ[12].MCR = 0x5555;//message object invalid
 CAN_OBJ[13].MCR = 0x5555;//message object invalid
 CAN_OBJ[14].MCR = 0x5555;//message object invalid
// Resetting the CSR otherwise the module would get into an initialization loop
C1CSR = 0x0000;
RTCinit();
void CAN_NQS_time_date(void)
 CAN_OBJ[0].Data[0] = time.hour;
 CAN_OBJ[0].Data[1] = time.minute;
 CAN_OBJ[0].Data[2] = time.day;
 CAN_OBJ[0].Data[3] = time.month;
 CAN_OBJ[0].Data[4] = time.year1;
 CAN_OBJ[0].Data[5] = time.year2;
for (i=0; i=7;i++)
                if (CAN_OBJ[0].Data[i] != CAN_OBJ[1].Data[i])
                                CAN_OBJ[0].Data[i] = CAN_OBJ[1].Data[i];
                else
                                CAN_OBJ[0].Data[i] = CAN_OBJ[0].Data[i];
                break;
 CAN_OBJ[0].MCR = 0xe7ff;
