ADC XC167
Hello
can someone help me
I have the XC167 microcontroller from Infenion and would like to write a simple code.
On the analog input at P5.5 and P5.6 is an analog voltage can be created.
These will then be changed and the stress values should be Strom1 and Strom2 returned.
Unfortunately this does not work and I can not explain why this is.
I get strange values
what i have to change my StartXC167.A66 except ADCDIS EQU 0;
thanks for any help.
#include <xc167.h>
#include <intrins.h>
#include <XC16X.h>
int AD_Strom_messung (int kanal);
void init ();
unsigned int Strom_Wert,Strom1,Strom2;
main ()
while (1){
 Strom1 = AD_Strom_messung (5);
 Strom2 = AD_Strom_messung (6);
}//ende of while
}//ende of main
void init ()
P5DIDIS = 0xFFFF ;
int AD_Strom_messung (int kanal){
  ADC_CON = kanal + 0x0080 ;//start the conversion in kanal
 do {
     }while (ADC_CON & 0x0100);//waiting for the conversion
  Strom_Wert = ADC_DAT & 1023 ;// read the result
  return Strom_Wert;
