Which directive should I use (in the command line) to change the output path for the object files.
I want to move the objects files to a different directory (folder) so that my project directory contains only source files.
I don't think there's a command-line option to just specify the folder - you'd have to include it in an OBJECT directive?
But you can check for yourself in the list of available options here: http://www.keil.com/support/man/docs/c51/c51_cm_dirlist.htm
Typically, you'd set this up via your makefile, or the uVision project (if you had one).
Andy, wrong link
the link is to "control directives available in the Cx51 Compiler."
what the OP needs is linker directives
http://www.keil.com/support/man/docs/bl51/bl51_ln_cmdprompt.htm
to the OP:
what I do is to copy everything to a 'build directory' and let the toold work there
@ECHO OFF call wipesl cd ..\ARbld\bslv @ECHO OFF if "%MUSDEB%"=="0" goto setmdb goto setno :setmdb @ECHO ON rem ********** DEBUG INFO IN FILE ********** @ECHO OFF copy ..\..\com\cond\dbgflcd.h debflgc.h >..\trash\trashbin goto setdn :setno copy ..\..\com\cond\dbgflcn.h debflgc.h >..\trash\trashbin :setdn copy C:\asdr\DCfmtbs.c *.* >..\trash\trashbin copy C:\asdr\DCutil.c *.* >..\trash\trashbin copy C:\asdr\DCpcav.h *.* >..\trash\trashbin copy C:\asdr\DCfmtbm.a51 *.* >..\trash\trashbin copy C:\asdr\DCfsc.a51 *.* >..\trash\trashbin copy C:\asdr\DCfsn.a51 *.* >..\trash\trashbin copy C:\asdr\DCbsc.a51 *.* >..\trash\trashbin copy C:\asdr\DCbsn.a51 *.* >..\trash\trashbin copy C:\asdr\DCmacro.inc *.* >..\trash\trashbin copy C:\aglobal\keil.h *.* >..\trash\trashbin copy C:\aglobal\cyf120.h *.* >..\trash\trashbin copy C:\aglobal\c51s.lib *.* >..\trash\trashbin copy ..\..\cms\*.h *.* >..\trash\trashbin copy ..\..\ARsou\sslv\*.a51 *.* >..\trash\trashbin copy ..\..\ARsou\sslv\*.c *.* >..\trash\trashbin copy ..\..\ARsou\sslv\*.h *.* >..\trash\trashbin copy ..\..\ARsou\sslv\*.inc *.* >..\trash\trashbin copy ..\..\ARsou\sslv\SLVident.h DCident.h >..\trash\trashbin copy ..\..\ARsou\sslv\SLVports.h DCports.h >..\trash\trashbin copy ..\..\ARsou\sslv\S2626.h DCfmt.h >..\trash\trashbin copy ..\..\ARsou\sslv\SSF022.a51 SLVdrv.a51 >..\trash\trashbin del S1616.h >..\trash\trashbin del S2626.h >..\trash\trashbin del SSF022.a51 >..\trash\trashbin del SSF011.a51 >..\trash\trashbin rem changing typ to stl should ARbld slv485 rem if a 26 pin non-color comes up OOPS if not exist cmplst.txt goto nocmdl del cmplst.txt :nocmdl call batasm SLVstart call batcmp SLVisr call batcmp SLViic call batcmp SLVmain call batasm SLVxdata call batasm SXzdata call batcmp SLVutil call batasm SLVarout call batcmp SLV485 call batcmp SLV1wire rem call batcmp SLVUmain rem call batcmp SLVUflsh rem call batasm SLVUasm call batasm SLVdrv call batcmp DCutil call batcmp DCfmtbs call batasm DCfmtbm call batasm DCfsn call batasm DCfsc call batasm DCbsn call batcmp SXfmtfmt call batcmp SXtools call batcmp SXsignid if not exist cmplst.txt goto naser echo on rem ///////////////////////////////// rem ///////// COMPILE ERRORS //////// rem ///////////////////////////////// type cmplst.txt | more rem saved in file cmplst.txt pause @ECHO OFF :naser if not exist as.lib goto usliex del as.lib :usliex c:\tools\keil\c51\bin\lib51 c as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a SLVutil.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a SLVarout.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a SLV485.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a SLV1wire.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a SLVdrv.obj to as.lib >..\trash\trashbin rem c:\tools\keil\c51\bin\lib51 a SXfsn.obj to as.lib >..\trash\trashbin rem c:\tools\keil\c51\bin\lib51 a SXfsc.obj to as.lib >..\trash\trashbin rem c:\tools\keil\c51\bin\lib51 a SZbsn.obj to as.lib >..\trash\trashbin rem c:\tools\keil\c51\bin\lib51 a SZbsc.obj to as.lib >..\trash\trashbin rem c:\tools\keil\c51\bin\lib51 a SXfmtbm.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a SXfmtfmt.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a SXtools.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a DCutil.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a SXsignid.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a DCfmtbs.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a DCfsn.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a DCfsc.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a DCbsn.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a DCbsc.obj to as.lib >..\trash\trashbin c:\tools\keil\c51\bin\lib51 a DCfmtbm.obj to as.lib >..\trash\trashbin REM c:\tools\keil\c51\bin\lib51 a SXfsn.obj to as.lib >..\trash\trashbin REM c:\tools\keil\c51\bin\lib51 a SXfsc.obj to as.lib >..\trash\trashbin REM c:\tools\keil\c51\bin\lib51 a SZbsn.obj to as.lib >..\trash\trashbin REM c:\tools\keil\c51\bin\lib51 a SZbsc.obj to as.lib >..\trash\trashbin REM c:\tools\keil\c51\bin\lib51 a SXfmtbm.obj to as.lib >..\trash\trashbin rem c:\tools\keil\c51\bin\bl51 SLVstart.obj, SLVisr.obj, SLViic.obj, SLVmain.obj, SLVxdata.obj, SLVUmain.obj, SLVUflsh.obj, SXzdata.obj, as.lib TO asl.omf RS(256) IX CO ( ?PR?_SLVUmain?SLVUMAIN (0xE000), ?PR?CUP*) >protl.log c:\tools\keil\c51\bin\bl51 SLVstart.obj, SLVisr.obj, SLViic.obj, SLVmain.obj, SLVxdata.obj, SXzdata.obj, as.lib TO asl.omf RS(256) IX >protl.log IF errorlevel=2 GOTO tell goto show :tell echo on rem //////////////////////////////////////// rem //////////// linker ERRORS ///////////// rem //////////////////////////////////////// rem errors and warnings are in protl.log rem link map is in as.m51 pause :show echo on type protl.log | more pause @ECHO OFF del *.lst del *.obj del *.lib rem del *.txt del *.log if "%MUSDEB%"=="0" goto getout :hexc1 c:\tools\keil\c51\bin\oh51 asl.omf HEXFILE (..\..\hex\022S%1.hex) echo on fc ..\..\hex\022S%1.hex ..\mtc\022S%1.hex pause type x.log :getout cd ..\..\mk
He asked about object files in the plural - so, surely, that must mean the object files created by the compiler?
Anyhow, if I misunderstood, he now has both interpretations...
It seems like one can't specify the folder for the object files generated by the compiler from the command line.
I guess I will have to accept the fact that there is object files between my source files.
I wish I could use the Keil IDE but then I won't be able to use my debugger :(
I wish I could use the Keil IDE I do not. Once I came to appreciate the total flexibility of running .bat for Keil together with CodeWright (an editor, not a "necesseray part of an IDE that does some editing") and whatever ICE I have for the chip in question there was no "wish to use the Keil IDE" left.
"It seems like one can't specify the folder for the object files generated by the compiler from the command line."
You can specify it - just not independently of the object file name.
It wouldn't be hard to do that in either a makefile or a .bat file...
"I guess I will have to accept the fact that there is object files between my source files."
Or you could just add a step immediately after your compiles to move them...
"I wish I could use the Keil IDE but then I won't be able to use my debugger"
How does the IDE prevent using your debugger?? Sure, it wouldn't be "integrated" - but I can't see any reason why you couldn't use uVision to do the builds (and editing, if you like), and a separate debugger for your debugging.
You could probably even arrange for your debugger to be launched via the uVision 'Tools' menu...
