Hello;
I am an almost a newbie on ARM/ I was trying to figure out how to configure a startup.s file. I worked on PLL settings a little and after that it started not to respond me. please note that I use different board and flash program (H-JTAG).
I have found that If I load a wrong pll settings , it won't respond me any longer until I load the correct settings manually.
Then, I tried to load correct setting via ISP. But whatever I have done , The micro doesn't enter the isp mode.
Thanks, Any help will be welcome
Adem
Wrong settings for the PLL is expected to not work. The processor just can't be trusted if overclocked.
How can we help you with your ISP problems? You only say "But whatever I have done" but you don't actually tell us what you have done. Post what you have tried, and the results, and then we can respond.
I have tried to enter isp mode using ISP21isp,philips flash utility,flash magic etc. None of them helped me.
JTAG still doesn't work. I am out of ideas.
is it ok if i simply solder a new IC ?
thanks alot for your help guys
