keypad in interrupt method
hi friends,
iam trying to write keypad programm using interrupt method and send the pressed key to terminal.
but iam not getting the char everytime.
  • And what do you expect anyone to deduce from that?
    There is a fault in your keypad input and/or your serial output and/or whatever you have between them!
    What "terminal" are you talking about? there could possibly even be a fault with that...
  • do you fix the attacks!!!!
    you ask questton and it is not given good with the item in the crown.
    Connector responsible for placing code and variables into available memory space. Linker document describes how to connect with local, certain objects / documents, in some locations memory
    sorry for correct english i convert to from software computer in the ceiling and he coughed
