Hi all, I wrote program using C51v8.11a in C language. Now i want to convert it hex file sothat I can transfer to the controller, is there any option in C51 only or I need to use some other software(please specify software). thank you
This process is called "Building" your project.
In uVision, you just press the appropriate button.
I suggest you start here: http://www.keil.com/support/man/docs/uv3/uv3_ex_hello.htm
