I need technical support for the following: i am using KEIL3 and infineon XC161CJ microcontroller . i am facing a problem that i have to write dyanamic data using serial232 port from computer to microcontroller. this data should go in flash memory area online , sothat when it is powerd off this data will not be lost. again on poweron this data should be avalable. i am unable to define a dyanamic variable in flash memory for this purpose. kindly suggest c program to define a variable in flash area which will be available after power off condition. how to write, delete. erase this dyanamic variable? waiting for early reply... thanks and regards.. kamlesh verma Defence research and development organization ministry of defence government of india
