I have downloaded the evaluation version of uVision3 V3.22 and I can't get compiled the default example code (project Blinky). I am getting the following error:
Build target 'MCB2100 Flash' assembling Startup.s... compiling Retarget.c... Retarget.c: Error: #869: could not set locale "" to allow processing of multibyte characters Target not created
Could you help me please with this problem? Thanks.
Does your code contain any multibyte characters?
What editor have you been using for editing the file?
Her are the compiler output messages:
Hi to all,
I got support from Keil support team (Mathias helped me). The problem for error #869 was related to correct language settings in Regional and Languages settings. Should be set into English. Thanks.
