i am searching for 'C' code for using the rotary encoder to input 4 digits and save them , then comapare the input code with a saved one.
i wish if any one can help
waled
When posting a question, please be specific. It makes a difference whether you:
1) create a code to handle raw input digital lines directly in your f/w. In literature, they typically referred to as lines #A, #B
or
2) you use a quadrature detector chip, like LS7084 which takes those #A, #B as an input and produces cleaned-up clock & direction signals which also must be handled as digital lines but in a different way ;-). The hint is: on C167 family you can map CLK/UP signals to the timer's TxIN & TxEUD inputs. BTW, there is solution based on using PCF8574, bus expander - see ref. b) below
3) you are going to use processed output from a specialized controller
Good start for you would be: a) google & learn b) www.circellar.com/.../2303017.pdf
-- Nikolay.
