I have declared this variable : unsigned int Test;
To set de MSB, i can make so : Test |= 0x80000000; it works ok, but if I make so : Test |= (1 << 31), the realview compiler claims :
warning: #61-D: integer operation result is out of range warning: #68-D: integer conversion resulted in a change of sign
But the two instructions both set the MSB, why the latter result in warning ?
Hi Marcelo,
In the second case, your 1 is, by default, a signed number. When you left-shift it by 31, you exceed the range for an unsigned int - hence the warnings.
Try :-
Test |= ((unsigned int) 1 << 31)
or
Test |= (1U << 31)
regards,
David.
Should be "you exceed the range for an signed int" above.
Thank you !
