Hi!!
I have a problem with timer. I have MCB2300 board with lpc2378.
In aplication I using RTL kernel, which use TIMER0.
Now I would like to have own timer TIMER3. I set:
void timer3_irq (void) __irq { T3IR |= 0x08; LED_out(0x49); VICVectAddr = 0; } void timer_init(void) { T3MR3 = 0x00003840; //set match channel 3 on 5ms T3MCR = 0x600; //Match register 3 enable //IRQ VICVectAddr27 = (unsigned long)timer3_irq; VICVectCntl27 = 4; //priority VICIntEnable |= 1<<27; //reset T3TCR = 0x00000003; //enable timer T3TCR = 0x00000001; }
Have I set wrong?
Thanke for your help
Peter Kic
"I have a problem with timer."
What problem, exactly, do you have?
Where do you update PCONP to turn on the power to the timer?
this was first mistake, now I added on the top of timer init:
PCONP |= 1 << 23;
but stil don't work
Hello Peter Kic,
Please code it like below than it will work.
__irq void timer3_irq (void) { T3IR = 0x08; LED_Out(0x49); VICVectAddr = 0; } void timer_init(void) { PCONP |= (1 << 23); //enable power to TIM3 T3MR3 = 0x00011999; //set match channel 3 on 1ms = 12000-1 at 12.0 MHz T3MCR = 0x600; //Match register 3 enable //IRQ VICVectAddr27 = (unsigned long)timer3_irq; VICVectCntl27 = 4; //priority VICIntEnable |= 1<<27; //reset T3TCR = 0x00000003; //enable timer T3TCR = 0x00000001; }
If have tested it on a MCB2300. Maybe the problem was that the __irq keyword was not at the beginning of the line.
Best Regards, Martin Guenther
