Hi everyone!
I'm a n00b to microcontroller programming so have patience with me :)
The mission is to handle some uart (rs232) communication, both rx and tx. My part is a small module going into a rest of the software already developed.
The issue is the following: When I use serial ISR it seems to not go into the "main while loop" (which is required).
(I've also tried to poll my self but reliability seems somewhat unstable, loosing a byte here and there)
I've tried the simplest demo/test programs and if I for instance use a printf in the while loop, it will not reach it as soon as ES = 1.
Is it just that any printf will not issue an interrupt and hence no output to my terminal? At the moment I can not test my module with the rest of the software so I'm a bit in the blind here, well could of course try to blink a led or something... but I reacon a answer from here is faster and more reliable :)
Thanks in advance
/Mike
If you look at the putchar() function (which is used by the printf() function), you should find that it actually uses polling. It's usually a bad idea to mix interrupt-driven and polling operation for a peripheral. You may need to adapt the putchar() function to operate the UART with interrupts.
"using printf() and using interrupt-driven operation on the UART at the same time is most likely a bad idea."
Not at all!
There is absolutely no reason whatsoever why you should not use printf with interrupt-driven serial IO provided you make the necessary changes to putchar() - See: http://www.keil.com/support/man/docs/c51/c51_printf.htm
See also: http://www.keil.com/support/man/docs/c51/c51_putchar.htm http://www.keil.com/support/man/docs/c51/c51_lib_source.htm
It's all clearly illustrated in the following Keil examples: http://www.keil.com/download/docs/200.asp http://www.keil.com/download/docs/71.asp You can use this code directly in your application - no need to re-invent the wheel!
