I need to make a 0.25us period timer for my 1-wire bus. How can this be implemented best? I have my CPU (LPC2378) running at 48MHz. Can this be achieved best with the use of timers?
I then need an exact multiple of this timing (from 1 to about 100)
When I make a function to set my timer or do anything else, then I already need 0.366us for just calling the function.
Can anyone help me?
PS: 1 CPU clock takes: 1/48MHz = 20.833ns
"I need to make a 0.25us period timer for my 1-wire bus."
Are you using Overdrive speed, then?
Otherwise, all you need is 1us accuracy for your timer - see: " href= "http://www.8052.com/forum/read.phtml?id=149030">www.8052.com/.../read.phtml
www.keil.com/.../armccref_cjabcdad.htm
I found this code:
#define NOPS(x) \ (((x) & 1) ? __nop : 0), \ (((x) & 2) ? __nop,__nop : 0), \ (((x) & 4) ? __nop,__nop,__nop,__nop : 0), \ (((x) & 8) ? __nop,__nop,__nop,__nop,__nop,__nop,__nop,__nop : 0)
normally the __nop's were _nop_() but that was for c51 code. So I thaught this would work, but it doesn't. My project does compile, but it's like the nop's are ignored. I have this code wich toggles a LED on my board:
const int getal = 12; void Delay_250ns(void){ while(1){ FIO2SET = 0x80; NOPS(getal); FIO2CLR = 0x80; NOPS(getal); } }
When I comment the NOPS() macro's above, the LED still toggles at the same speed. Without these NOPS the toggling period is about 60 ns (a little longer for falling edge). 1 clock period = 1/48MHz = 20,83 ns When I put 12 nops my toggling period would have to be 250ns. But it doesn't seem to do that...
Here some info about __nop in RealView compiler: www.keil.com/.../armccref_cjabcdad.htm
Looks like optimization can't be the cause.
Anybody knows what my mistake could be?
thx
First, back to my original question, do you really need the 250ns precision? If you don't then, surely, an assembler function must be the best way to do this?!
If you really do need the 250ns (which would only be if you're using overdrive speeds) then, I suppose, you'll have to pursue the NOPs...
As the Application Note 126 says, there are only ten different timings required in each set; Therefore, rather than try to debug a "clever" macro, why not just define a set of macros; eg,
#define DELAY_A (however many NOPs for the 'A' parameter in Table 2) #define DELAY_B (however many NOPs for the 'B' parameter in Table 2) etc...
If you want to pursue the "clever" macro, then start by examining the preprocessor output - to ensure that it is expanding correctly;
If that's OK, examine the generated code...
