Hi ,
I have bought a MCB23xx development kit. We have to make a application on a windows XP machine which is going to talk to the MCB23xx board via the USB interface of the PC.
I have already configured the MCB23xx board to be a Human Interface Devices (HID) USB class type by downloading the HID example code firmware using a keil ulink2 debugger.
The code was picked up from the keil site and also i have tried and used successfully the HID client example code which is VC++ based for toggling few LED's on the board and sensing the keyboard interrupt.
My task is that i have to make a new vc++ based application which is going to have a edit box and when we type some thing in this box and when we click a send button on this GUI the typed string should go to the MCB23xx board and then appear on the LCD display present on the board.
Here are the few questions: 1)Has anyone used/worked on HID client (Host Side (PC) side) vc++ application. 2) Can i send the a string if i configure the evaluation board to be HID class type? 3)Can anyone provide me a documentation for the HID (VC++) based client application present on the keil site? 4) Also a documentation of the HID example code present on keil site would be very helpful, Has anyone used this code (Board side) for their custom application?
I will be grateful if someone answers my queries.
Thanks in advance, Amit
http://www.keil.com/forum/docs/thread11513.asp
