Im using RTX kernel with the TCP Net library. The manual says I have to do all my Tcpnet jobs in one task ...
So , I have to manage some events for each Tcp socket used. (connecting, sending data , deconnecting) . I want to use the os_evt_wait_or() function with switch/case but the tcpnet requires a polling of main_tcp()
So is it possible to use os_evt_get() in order to avoid to much latency for the main_tcpnet to be called, like this ?
void tcp_task(void) __task { ... while(1) { main_TcpNet(); switch (os_evt_get()) { case ... case ... } } }
Or I have to use os_evt_wait_or() like this :
void tcp_task(void) __task { ... while(1) { main_TcpNet(); os_evt_wait_or(mask,100ms) switch (os_evt_get()) { case ... case ... } } }
Thanks in advance
