Hello everyone, I am studying link list in c I have a project in which I have lookup table of rpm (clocks used to load the timer used for motor). This rpm table, I am taking in an array Now I want to implement a link list which will access the rpm from table and load it to timer of clock used for running the motor Is it possible Because as I am studying the link list, in that it is mentioned that link list is used instead of array Is it possible to access an array elements using link list ? If yes, then pls suggest me some link for it Correct me if I am wrong Thank u all
"When you have a hammer, especially the shiny, brand-new one that you always wanted, every problem looks like a nail."
you just brought to my attention what started this whole thing. Again it is/was related to the unfortunately very often missing information "what for" in the OPs post.
All I can say is that in the instances (more than a few) where I have considered a linked list for a '51 app I whave found the method inefficient in the respect of throughput due to a lot of 'external memory pointer replacements' which the '51 is not the champion of. Thus I consider linked lists 'hungry' which does not mean that I would not analyze the app of such (again) should the occasion arise.
Now had the OP stated what for, this could have been a discussion instead of a 'hurling'
