LPC 2138 compiler settings problem
I've bought a sparkfun logomatic v1.0 to change reprogram as an advanced datalogger. There is a lpc2138 onboard and it is possible to program it with the lpc2000 flash utility.
I've tried to compile a test progam, just to blink some leds on P0.x but the processor seems to do only the first command. I believe there is somewhere a parameter in the compiler settings I've mist.
I set up for a lpc2138 changed the freq to 147.456 MHz, IROM from 0x4 to 0x7FFF, IRAM from 0x40004000 to 0x40007FFF just like detailed in the datasheet.
#include <LPC213x.H>
void delayms(int j) {
        unsigned int i;
        unsigned int k;
        i = 0;
        k = 0;
        while (i != j) {
                k = 0;
                while (k != 14746) { k++; }
                i++;
int main (void)  {
        PINSEL0 = 0x00000000;
        IODIR0 =  0xFFFFFFFF;
        IOCLR0 = 0xFFFFFFFF;
        while (1)  {
                IOSET0 = 0xFFFFFFFF;
                delayms(1000000000);
Is there anything I'm missing?
Thanks in advance,
Ruben
