hi all
this is how i initialize the timer1
void init_timer1(void) { T1MR1 = 15999999;//15990; T1MCR = 3; T1TCR = 1; T1CTCR = 0x00; VICVectAddr5 = (unsigned long)T1_IRQHandler; VICVectCntl5 = 14; VICIntEnable = (1 << 5); }
__irq void T1_IRQHandler (void) { volatile unsigned int pin_status; pin_status = FIO4PIN;
if((pin_status & 0x20000000) == 0x20000000) { FIO4CLR |= 0x20000000; } else { FIO4SET |= 0x20000000; } }
this timer1 is not working in timer0 and timer1 i have initialized as similar which toggles the pin every one sec.here timer0 generates the interrupt and i get the pin toggled but i have the problem with timer1 the pin doesnt toggle so i doubt tht timer1 is not initialized or its not able to generate interrupt so can any one help me to rectify the doubt i have given the code how i initialize the time and the interrupt code ...the default PCONP is set .
Regards suresh
Why a new thread - and still with incorrectly posted source code? Kill off this thread, and return to the original thread.
I forgot the obligatory link to the "correct" thread: http://www.keil.com/forum/docs/thread10860.asp
the above code works for timer0 but not for timer1 so wt might be the problem ......do i have to set any other register to make it work
If you expect answers, please keep your discussion in the correct thread!
Starting a new thread wastes other peoples time, since they don't know what have already been discuessed! If that is important to you, please show that!
Hello Suresh Kumar,
You must acknowledge the interrupt in your interrupt service routine.
The following code runs on a Keil evaluation board MCB2300 and toggles the LEDs P2.0, P2.1 with 1Hz.
/* Timer0 IRQ: Executed periodically */ __irq void T0_IRQHandler (void) { volatile unsigned int pin_status = FIO2PIN; if (pin_status & (1 << 0)) FIO2CLR = (1 << 0); /* LED off */ else FIO2SET = (1 << 0); /* LED on */ T0IR = 1; /* Clear interrupt flag */ VICVectAddr = 0; /* Acknowledge Interrupt */ } /* Timer1 IRQ: Executed periodically */ __irq void T1_IRQHandler (void) { volatile unsigned int pin_status = FIO2PIN; if (pin_status & (1 << 1)) FIO2CLR = (1 << 1); /* LED off */ else FIO2SET = (1 << 1); /* LED on */ T1IR = 1; /* Clear interrupt flag */ VICVectAddr = 0; /* Acknowledge Interrupt */ } int main (void) { PINSEL10 = 0; /* Disable ETM interface, enable LEDs */ FIO2DIR = 0x000000FF; /* P2.0..7 defined as Outputs */ FIO2MASK = 0x00000000; /* Enable and setup timer interrupt, start timer */ T0MR0 = 11999999; /* 1sec = 12000000-1 @ 12.0 MHz*/ T0MCR = 3; /* Interrupt and Reset on MR0 */ T0TCR = 1; /* Timer0 Enable */ VICVectAddr4 = (unsigned long)T0_IRQHandler;/* Set Interrupt Vector */ VICVectCntl4 = 15; /* use it for Timer0 Interrupt */ VICIntEnable = (1 << 4); /* Enable Timer0 Interrupt */ /* Enable and setup timer interrupt, start timer */ T1MR0 = 11999999; /* 1sec = 12000000-1 @ 12.0 MHz*/ T1MCR = 3; /* Interrupt and Reset on MR1 */ T1TCR = 1; /* Timer0 Enable */ VICVectAddr5 = (unsigned long)T1_IRQHandler;/* Set Interrupt Vector */ VICVectCntl5 = 15; /* use it for Timer0 Interrupt */ VICIntEnable = (1 << 5); /* Enable Timer0 Interrupt */ while (1); /* Loop forever */ }
Best Regards, Martin Guenther
sorry i had the acknoledge statement it some how got missed it the above published code ... its working now the mistake was i loaded the value in TXMR1 instead of TxMR0. so when TXMR0 is loaded with the value the timer is working but y not when TxMR1,TxMR2,TxMR3 any reason to make it workable ....
