Did anybody make a bootloader for mcbstr9?
Hallo. I have a problem and need your help.
I use mcbstr9 and Keil 310.
I remade ST IAP driver for KEIL. There is a bootloader ( bootloader is in flash bank1 and the main programm in flash bank0. When a definite event doesn't occur ( Z/B an interrupt by pressing a button on the board) the main pogram runs, else you see a menu in hyperterminal and you can download new main Program). But it is a problem with this driver. When I press reset button controller buzzs.
I think it is so, because when reset occurs not all registers are set to their reset value, videlicet FMI and some SCU registers. That's mean that controller loads from small flash (bank1), but doesn't find a 0x0000 addr here!
Did anybody solve this problem? /* I need a reset button in my Program. I would thank you very much, if somebody could help me.
