Dear friends,
I am writing a small code for an 89LPC935 and KEIL uVision3 + MCB900 board, and all goes good untill i try to enter the If .. else statement :((
Take a look and give me some tip if available >>>
If (Keyb_input == 0x0B); // Keyboard "Play" press { Debug++; // Increment Debug register P2 = Debug; // Debug keypad press to Port2 }
Notes: (*) The Keyb_input is declared at the begining of the program as unsigned char data Keyb_input
(*) Error messages are >> missing function prototype requires ANSI-style prototype
My dearest friend,
Look at your line:
See the semi-colon - Get rid of it and you should see something better.
Kindest regards,
Happy Happening.
Dear friend , i am sorry to bother you again but something is wrong t my code even if i discard the semicolon from the If statement :(((
Here is the total C code (Thank god it is small :( )
// Author: Timothy Kondos // Date: 24.06.2008 // #include <REG935.H> sbit Status_led = P0^0; // Initialize P0.0 as the status led unsigned char data overflow_count; // Define system interrupt as a variable unsigned char data Keyb_input ; // Keyboard input register(8bit) unsigned int Counter_us ; // Microsecond counter(16bit)-ISR usage unsigned char data Debug ; // Special user register (8bit)-Debug usage Delay_20ms(void) { Counter_us = 0; // Reset Counter_us 16bit register while (Counter_us <= 400) // Wait until 20ms elapsed { } } void timer0_ISR (void) interrupt 1 { Status_led = 1; // Open Status led Counter_us++; // Increment microsecond counter(16bit) Keyb_input = P0; // Read keyboard Keyb_input = Keyb_input & 0xF0; // Isolate upper nibble/Ignore lower nibble while((ADCON1 & 0x08) == 0); // Wait for end of conversion { } ADCON1 &= 0xF7; // Clear EOC flag Status_led = 0; // Close status led } main (void) { //Port0 configuration P0M1 = 0xF0; //Initialise P0 as I/O P0M2 = 0x01; //Port2 configuration P2M1 = 0x00; //Initialise P2 as I/O(All Quasi Bidirectional) P2M2 = 0x00; //Timer0 module configuration TMOD = 0x02; // Initialise Timer module in Mode2 TAMOD= 0x00; // Initialise Timer module in Mode2 TL0 = 0x48; // Initialise TL0(temp reload) value TH0 = 0x48; // Initialise TH0(auto reload) value IEN0 = 0x82; // Enable interrupts on timer0/Enable global interrupts TCON = 0x10; // Start timer0 //Configure the ADC module 1 configuration ADINS = 0x40; // Select AD12 as ADC input (P0.3) ADCON1 = 0x24; // AD1 enabled/Single Step/Trigered on timer overflow ADMODA = 0x20; // Single step on channel 1 of A/D ADMODB = 0x60; // ADC clock is set to 3.3MHZ(fCLK/8) Debug = 0; // Reset debug register while (1) // Loop forever ("Super loop") { while (Keyb_input == 0xF0) // Reloop and read keyboard again (No keyboard suspected activity) { Delay_20ms(); // Call the Delay function } If (Keyb_input == 0x0B) // Keyboard "Play" press { Debug++; // Increment Debug register P2 = Debug; // Debug keypad press to Port2 } } }
Same error message as before .. If statement denies to be compiled.
Just compile it and the error comes :(
What could be wrong (?)
Thank very much for your time Timothy
"If" with capital letter?
Dear coding friends,
I didnt thought "C" programming was so strict grammar sensitive. Anyway, it worked , just replacing the capital "I" to if statement. All ok now ,
Thanks again all:)) Special thanks to Ulf Saß
You should also look at the code relating to 'counter_us'.
1 - It should be volatile, since it is being sampled repeatedly by your Delay_20ms function and is being updated by an ISR. The optimizer (probably) will do things that I suspect you currently do not consider.
2 - In the same vein, the variable is a 16 bit integer; i.e., stored in two bytes (on an 8051) so while the delay loop is half way through accessing it, the ISR may come in and changing the value.
You might get your code to compile, but without considering these points, you might find the operation isn't always as you intend; i.e., buggy.
