This has been a frequent question recently, and the frequently-given answer is:
GNU support in uVision is now available via CodeSourcery. See: http://www.keil.com/appnotes/docs/apnt_199.asp
See: http://www.keil.com/forum/docs/thread12535.asp http://www.keil.com/forum/docs/thread12663.asp http://www.keil.com/forum/docs/thread12720.asp etc, etc...
My question is: if you've got Codesourcery - which includes a complete toolchain, IDE, debugger, etc - why would you also want uVision?
Quite a complete packages indeed: www.codesourcery.com/.../components.html
I was thinking (peripheral) simulator but it's also included, in some form. Perhaps it's a substitute for ARM but maybe not for other architectures? Hmm, seems to be ARM mostly anyway.
In that case I don't know but the Keil/ARM sales people probably have an answer :-)
-- J
How about this: Keil uVision evaluation version + CodeSourcery G++ Lite = Free IDE without code size limit. Great for a hobbyist. I have not tried it, but have considered..
Anybody with experience of this combination have any comments?
I saw the instruction set simulator but not a peripheral simulator.
Most embedded applications are difficult to simulate because interrupt and on-chip peripheral simulation are required. Startup code is especially troublesome because of timer, bus, and power control settings that require some kind of simulated feedback.
Maybe that (limited in the eval version) capability is enough for many developers to get started.
Jon
"Keil uVision evaluation version + CodeSourcery G++ Lite = Free IDE without code size limit."
But the evaluation version of uVision does have code size limits!
As you said above, simulation in Keil eval version has problem with peripheral simulation (startup.s is an example). So, when I simulate the code segment of LPC2300.s file below. It can't jumb to Reset Addr. It only run sequentialy to the NOP and get stuck. Is it that problem ?
Vectors LDR PC, Reset_Addr LDR PC, Undef_Addr LDR PC, SWI_Addr LDR PC, PAbt_Addr LDR PC, DAbt_Addr NOP ; Reserved Vector ; LDR PC, IRQ_Addr LDR PC, [PC, #-0x0120] ; Vector from VicVectAddr LDR PC, FIQ_Addr Reset_Addr DCD Reset_Handler Undef_Addr DCD Undef_Handler SWI_Addr DCD SWI_Handler PAbt_Addr DCD PAbt_Handler DAbt_Addr DCD DAbt_Handler DCD 0 ; Reserved Address IRQ_Addr DCD IRQ_Handler FIQ_Addr DCD FIQ_Handler Undef_Handler B Undef_Handler SWI_Handler B SWI_Handler PAbt_Handler B PAbt_Handler DAbt_Handler B DAbt_Handler IRQ_Handler B IRQ_Handler FIQ_Handler B FIQ_Handler
Cheer
