Hello everyone, I m interfacing a RTC of ds1307 with microcontroller c8051f020 I follow rtc datasheet My circuit is working fine. In the software, I m initializing the interrupt then smbus and after that rtc. Initialization of rtc includes initializing internal oscillator and generation of 1 sec pulse 1 sec pulse is used as 1 sec interrupt I read rtc after every one sec in while(1) loop. Flag is set in 1sec interrupt routine and display time on lcd My problem is, when I switch on the machine I find the lag in seconds To test it I switched off and on the machine several times and it was noticed that seconds lag is increasing To check again, I downloaded the program and reset the microcontroller for several times and run it Still I get lag in seconds as I increase the resets of microcontroller Is it a mistake of my code or hardware fault? Lag is of few seconds but if this continues then in a month it will be in minutes thank u all
