help....
I am newer to c8051f120. My problem is that i wrote the 4 bit LCD code its work nicly .When i switch off and switch ON the supply to devlopment board its giving error o/p i.e undefined symbole but once again i reset the microcontroller using hardware reset pin it gives correct output.What is the problem
