Hi all,
I'm dealing with a cy7c68013a and the framework cypress provide. The fw use a jump table for usb interrupt but I've to add some ISR for INT0 and serial comm.
Do I need a .a51 file like this?
;INT0 vector handler EXTRN CODE (ISR_INT0) CSEG AT 0003H LJMP ISR_INT0 END
And inside C code:
void ISR_INT0(void) interrupt 0 {...}
What does mean "interrupt 0"? I can't find documentation about syntax of ISR ... fw already uses "interrupt 0" do I've to use 1?
Thanks a lot
"fw already uses "interrupt 0"
You are missing this pragma is declared at the top of the source code of Cypress examples.
#pragma NOIV // Do not generate interrupt vector
Then, the USB ISRs on the example don't generate any vector.
Tsuneo
In other words...
Normally generates the interrupt function and the vector-you need create no assembler code.
However, the NOIV pragma is used in the cypress examples. This pragma instructs the compiler to exclude interrupt vectors (and you must manually create them in assembler).
Jon
Thanks for your help guys!
Maybe I didn't explain myself too well ... I spotted the NOIV pragma and for this I'd to put some assembler code like this: "CSEG AT 0003H LJMP ISR_INT0".
My doubt was about C code. I can't find documentation about writing ISR with C51, so I can't understand what "interrupt X" means inside declarations like this:
I see cypress fw already uses "interrupt 0", Do I've to use "interrupt 1"? Can I share "0"? What does mean that number?
Dax
That's easily fixed:
http://www.keil.com/support/man/docs/c51/c51_le_interruptfuncs.htm
