Dear all I encountered a problem while monitoring port pins using LPC2368 with KEIL ULINK2 debugger & Keil microvision3. I have initialized Port pins P2.0 & P2.1 as I/P pins. I am monitoring these pins through polling
Here is the code which i have written for this purpose.
FIO2DIR = 0XFFFFFFFC; //Port 2.0 & 2.1 --Input /// FIO2MASK = 0xFFFFFFFC; //Only P2.0 & P2.1 enabled while(1) { while( (FIO2PIN & 0x00000001) ) // Polling P2.0 { ............ ............ } while( FIO2PIN & 0x00000010 ) // Polling P2.0 { .............. .............. .............. } }
In this program pin P2.0 is working correctly ie when connected to Vcc entering the loop & when connected to ground its coming out of the loop But with P2.1 its not the same thing. The status of the pin is not getting detected. What may be the reason for this or can you please tell me where i am going wrong ...Please help me to solve this problem
Thanks & Regards Giridhar
Hi, try to verify that bit 3 of PINSEL10 register is 0. If this bit is 1 port 2 are controlled by ETM interface and pins are not configured as general I/O despite of the configuration of PINSEL4 register.
Bye,
Demis
I.e. normal numbers (12, 42, 65000, etc) are decimal, 0x... numbers (0x1A, 0x4, 0x001, etc) are hexadecimal, not binary.
-- J
Hello Giridhar,
try pre while( FIO2PIN & 0x00000002 ) // Polling P2.1 /pre
There is no binary constant in C!
Regards Martin
