hi to all As i am startd working with P89v51rd2.i am facing some problem some chips are burinning properly and some are not i am uaing ALL-11C2 universal programmer to programming the controller As there is no problem in H/W as some IC's are working properly but some are not i placed the user code on block 0. as i shifted from 12 CLK to 6 CLK at ALE i am getting 4 MHz and 8 MHz Freq respectively. Crystal is 24 MHz .so i think there should not any problem with programmer with this i am attaching the code please guide me where is actual problem.
#include <P89V51Rx2.H> #include<intrins.h> #include<define.h> /*******************************************************************************************************/ volatile unsigned int TimeTick1ms; void TMR_1(void)interrupt 3 { TR1 = STOP; TL1 = COUNT_LO_1mS; TH1 = COUNT_HI_1mS; TR1 = RUN; TimeTick1ms++; if(TimeTick1ms & 0x01) {P1 =~P1;} if(TimeTick1ms >= 100) { TimeTick1ms = 0; P3 =~P3; } } void main(void) { FCF = 0x01; //FST = 0x00; P0 = 0x3f; P1 = 0xff; P2 = 0xf8; P3 = 0xff; IEN0 = 0x88; TMOD = 0x11; TH1 = 0x63; TL1 = 0xBF; TR1 = RUN; TimeTick1ms = 0; while(1) { P2 =~P2; P0 =~P0; } }
